Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-15-2005, 04:37 PM
Rajkumar Rajkumar is offline
Check Engine Light on
Check Light is On of My Pontiac Bonneville 96. I got it checked at AUto zone and the error code is P0102. If any one can help me to fix it and reset the computer. I will really appreciate the help.
Old 07-15-2005, 05:59 PM
michael_k0's Avatar
michael_k0 michael_k0 is offline
Send a message via Yahoo to michael_k0
Re: Check Engine Light on
try cleaning the MAF sensor and check all of the connections and wires. to reset the computer, disconnect the battery and let it sit for about 10 minutes with the key and the lights on. be sure to save your radio codes.
Old 07-16-2005, 12:40 PM
Re: Re: Check Engine Light on
Thank you very much Michael. I will try and I will post what happened. Thanks again much for sharing the info. By the way where is the MAF sensor in the Car.
Old 07-18-2005, 01:23 PM
I tried to clean the MAF sensor (which I think is very close to the Air Cleaner Filter.) I cleaned it and reset the computer but still I am getting the Check Engine light. Any further solutions.
Old 07-23-2005, 11:38 AM
Unhappy Check Engine Light Still ON
I cleaned the MAF sensor. Ithink it was MAF sensor which is very close to the Ait filter. After cleaning also it didn't worked. I removed the battery connection for more than ten minutes the Check Engine light went off for some time than it came back on. Can anyone tell me the sensor I cleaned is the MAF sensor or some other. If it was the right sensor do I need to replace it. Is there any solution for the problem.
