cost to replace oil pump?
what is involved with the oil pump? does the engine have to be taken out? what kind of cost am i looking at? the oil pumps like $200, right? how bout labor cost?
http://www.penguinhosting.net/~bigma...p/oilpump.html
its probably around a 200-250 labor charge from a shop
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: cost to replace oil pump?
They said it would cost right around $700 parts and labor to do it. The timing belt, oil pan, and of course the oil pump needs to come off. They also said to keep in mind that when the main bearings go up, you can loose pressure that way too. Hope I was of some help.
-Speed = Money... How fast do you wana go? |
700 parts and labor...hmmm. here's another opinion. http://www.bobthegreat.com/pages/myc...rbo/index.html --> click on Oil Housing. Bob says you don't have to remove the timing belt, which would cut down the labor time by at least 1 hour. you could do all the labor yourself, its pretty simple for anyone mechanically interested. you might have a friend help.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Also you could check www.thepartsbin.com for a cheaper pump.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: Re: cost to replace oil pump?
Re: Re: Re: cost to replace oil pump?
. nice to meet you too! mistakes are made, and overlooked here. we try to be nice about correcting people. but if you wanna spend 200-250 labor, and if you've got the money to throw around, then have at it. I was just trying to show you that its a simple job (in fact, the timing belt, though time consuming, is actually easy too) that you could do with a friend and save some money, since not all of us have money to throw around.
Re: Re: Re: Re: cost to replace oil pump?
Let's start over!!! Thanks for welcoming me to the board. (lol, I'll ignore the flip).
pax este nobis
