Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-15-2005, 01:41 PM
91integ 91integ is offline
problems starting on hot days
I have a 91 intrgra...I 've noticed that on hot days when my car has been left out in the sun that the car sometimes won't start. The starter seems to work fine but the engine doesn't turn over. If I shake the car a bit and keep trying it eventually starts after a while. The car runs fine after that. Any ideas why?
Old 07-15-2005, 03:03 PM
V T E C H's Avatar
V T E C H V T E C H is offline
Re: problems starting on hot days
try turning your heater on and letting that blow for a while. as for why you are having a hard time starting, i couldnt tell you.
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 07-16-2005, 01:35 PM
CBURKE's Avatar
CBURKE CBURKE is offline
I will bet you $$$ it's your main relay. It's under your dash driver side, says main relay. I read that whe they get hot you may have problems starting the car. I may be wrong, but they did kinda make them sucky back then.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 07-19-2005, 12:12 AM
92gsr200k 92gsr200k is offline
I use to have that problem with my '95 Civic and it needed the distributor cap and rotor replaced, but same thing happened recently with my '92 GSR and I did the same replacement and didn't help, so I'm going with the main relay now. It should just be under the steering wheel and it's a large cube thing. I'll check my '92 and write later.
Old 07-22-2005, 12:30 PM
Kurzheck's Avatar
Kurzheck Kurzheck is offline
AF Premium User
main relay 39400-SH3-003
Corner 5 Hobbies
Guelph Plastic Modellers Group
www.thesprue.com
