Old 07-15-2005, 12:29 PM
unicyclemidget11 unicyclemidget11 is offline
low oil pressure. help please
when i start my car and drive it for like 10 min my cars oil pressure is fine. then when i stop at stoplights i notice my oil light starts to flicker faintly. After i drive it more, it becomes more noticable. I have a 93 vr4. Im running synthetic 5w-50. would this be the cause of it? its been around 70-95degrees in last couple weeks. should i change my oil?
Old 07-15-2005, 01:58 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: low oil pressure. help please
sounds like your oil may be low, have you checked that?
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 07-15-2005, 02:55 PM
its in between the two notches.
Old 07-15-2005, 03:26 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
when you stop and get the load off the car like at a stop light it will be lower, liek in the first 3-4 notches... thats normal but when driveing it should be little over the middle of the guage...
Upgrades... To many to list...
Old 07-15-2005, 06:41 PM
no. (lol) on the dipstick its in between the two notches after the car had time to cool.
Old 07-15-2005, 11:20 PM
92VR4Red's Avatar
oh i was talking about the guage
Old 07-16-2005, 02:49 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
if its in between the two notches on the dipstick after it has had time to cool, then that means your low on oil. put some oil in it, start it up, then check your oil level again. you want your oil level to be even with the top notch on the dipstick DURING IDLE.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
