Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-25-2002, 09:44 PM
Perry63 Perry63 is offline
Question Heater Fan Switch Problem
I have a 1996 Nissan Maxima with a heater switch that only runs in high speed mode (#4 on the dial). There is no difference whether I have it on heater mode or A/C mode in terms of speed variations. Is this a defective swich or is there some sensor that may be creating this condition? Is there place I can continuity check the switch without having to remove parts of the dash assembly before I get into major repairs?
Thanks
Old 04-26-2002, 07:25 AM
NJMAXSELTD NJMAXSELTD is offline
Your fan switch is fine.
You need a new resistor block.
The resistor block controls the fan speed. It's located on the HVAC ducts (quack - quack) under and behind the glove box. It sits on the air duct after the fan motor. There is a connector with several wires on it. Unplug it, remove the resistor block from the duct and replace it.
Go to your Nissan dealer to obtain the resistor block first so you know what to look for once you get under there.
Your fan speeds 1,2, & 3 will work once you replace the resistor block.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 04-26-2002, 05:21 PM
Thanks so much for the thorough and complete answer to my question. I am very pleased with the response and assume that it won't be too difficult to get a resistor block to replace it. Will just removing the glove box be enough room to get to the duct (quack)? I won't have to remove any of the dash to get to it will I?
Old 04-29-2002, 07:57 AM
Re: Heater Fan Switch Problem
Yes
No
AC / Heater Fan speed Switch ibkafn8ed Cherokee 0 07-05-2009 02:26 PM
Heater fan switch? Or Relay problem? 57chevyragtop Impala | Impala SS 29 03-22-2008 03:22 AM
heater fan switch does not work on high schaapy32 S-10 1 10-18-2005 09:02 AM
99 Cherokee heater fan switch mightymouse466 Cherokee 3 10-07-2005 01:49 PM
02 RAV heater fan switch Uleesis RAV4 0 01-14-2005 01:10 AM
