Old 07-15-2005, 11:01 AM
RickySabotage RickySabotage is offline
Coolant leak...1990 ???
Was driving to work this morning and coolant started to leak, but I couldn't tell from where. SO I'm asking you guys, what might it be. All i know is any rad I've seen blown usually coats the fan blades in coolant and there wasn't any. It was on the block mostly. I can't see any leaking hoses on first inspection, but haven't had time to go under the thing yet. There was coolant under the block as well.
So, I'm thinking blown hose somewhere...what do you think?
Thanks in advance
Rick
Old 07-15-2005, 11:17 AM
chili chili is offline
Re: Coolant leak...1990 ???
Thanks in advance
Rick
Check your pressure bottle and cap thats where my 90 is failing now
good luck
Chili
Old 07-15-2005, 07:22 PM
Thanks...but I found it...the smallest of pinholes on the under side of a hose that I never seen until I filled the coolant back up, and let it run.
Cheers!!
