Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-15-2005, 12:01 PM
schaas schaas is offline
1994 Cutlass. OBD I or II?
1994 Cutlass with 3.1 L. Is this thing OBD I or II?
I tried using a jumper to get codes. No luck.
Autozone couldn't scan it either.
Old 07-15-2005, 04:03 PM
datpimp1 datpimp1 is offline
its a obd 1 , autozone well atleast the one here only scans obd 2 cars. And the reason you cannot jump terminals for codes is because the 94,95 cutlass have a obd 1 connection ( where yo plug the scanner) but and obd 2 system. because thats when they started to change over . I hope im clear kinda hard to explain but i tryed to do the same thing and that what i was told hope it helps. I dont know about where u live but here in chicago u can rent the obd scanner that does both 1 and 2 u jus pay full price and then when u return it u get a full refund
Old 07-15-2005, 09:11 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1994 Cutlass. OBD I or II?
Did you jumper the 2 top right hand holes then turn your keyswitch on?
Does your Check Engine light come on for a coupla seconds after turning on the keyswitch normally...no jumpers?
Old 07-18-2005, 12:50 PM
Yes, the check engine comes on during normal operation, no jumper.
There are 3 terminals in the connector. I jumpered every combination, 2 at a time. When I turn the ignition on the check engine comes on and stays on, no blinking.
Old 07-18-2005, 08:50 PM
AF - Advisor
The OBDI diagnostic port on my stuff have 12 holes...6 top & 6 bottom. It's located at the lower dash near the steering column.
Old 07-19-2005, 12:16 AM
im telling you im pretty sure you cant jump these obd1 on this vehicle but if you can i be shocked but let me know so i can do it
Old 07-19-2005, 07:46 AM
Chris Stewart, my port is the same. What year is yours?
Can you jumper yours and get codes?
I guess I'll call the dealer to find out what mine is for sure.
Old 07-19-2005, 06:38 PM
AF - Advisor
Well I'm learning...Datpimp knows what he says. My cheapo manual says take a '94 to a dealership to get the codes read....figures, I've been thinking about a '94 Bravada...until today.
Old 07-21-2005, 01:14 PM
Advanced Auto was able to scan it with an OBD II scanner, but the guy had to use a specific adapter plug to fit a 94 Cutlass.
Turns out the EGR was bad.
Thanks everyone for the info.
Old 07-21-2005, 06:29 PM
AF - Advisor
Thanks for getting back with us Schaas!
Old 07-24-2005, 06:49 PM
94cutlatized 94cutlatized is offline
Send a message via MSN to 94cutlatized Send a message via Yahoo to 94cutlatized
yo, thanks man, autozone kept telling me my connector was bad, i'll go to advance today
