Old 04-25-2002, 09:32 PM
defuse411 defuse411 is offline
do the 2001 civics and the 2002 have the same motors?
Old 04-27-2002, 02:42 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
as far as i know
Old 04-27-2002, 10:10 PM
what are the things that are differant for the "supper clean emissions"?
thanx for the input
Old 04-29-2002, 02:46 PM
Marasmus Marasmus is offline
Send a message via Yahoo to Marasmus
Definitely NOT the same engines..
For 2002, Honda changed their entire Small Car Platform (or whatever they call it), which includes the Civic and the RSX. The engines have changed quite a bit. No longer do they rotate counter-clockwise - they are now clockwise motors like most other manufacturers. The intake manifold is in the front by the radiator, which is new to honda as well. Transmission is on the driver's side instead of the passenger's side... basically the entire engine compartment got spun around 180 degrees.
The internals are also very different. If I understand it correctly, the base civics are using a 1.7l engine now, while the SI and Type-R use toned-down versions of the 2.0l block from the base RSX. Previous generations of civics used 1.6l engines.
They really screwed the Civic SI's motor hard... it's basically the base RSX motor, mounted in the civic frame, with a low-ass 6800rpm redline. They give the civic a wussy radiator and mount it completely under the bumper to make it unserviceable by mere mortals. It's frustrating to me that they don't push the envelope a little more on their product lines' performance... we all know the RSX can easily be tuned past 200hp and the civic SI should have been upgraded from 160hp (for the last, what, 10 years) to 200, considering it got a displacement upgrade as well. It's pretty annoying.
Old 04-30-2002, 08:15 AM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
the new civic si engine still has the same 160hp as it always did. the new marvel of it is the 132lbs. torque.
but they still should have used the rsx engine. 200hp just has that lovely sound.
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
Anyone know the wheel size and bolt pattern on the M12's? pacethis M12 7 12-26-2006 02:37 PM
(FOR SALE) Zip Zap Fast & The Furious Civic and Booster Pack ShOrtyOC714 Remote Control Cars 0 03-16-2004 05:16 PM
S4 smokes civic and runs 12's in the process MaximusGTR '94 - '01 6 03-15-2004 09:59 PM
