hyundai sonata transmission
what effect will it have if i use ATX in the gearbox
Re: hyundai sonata transmission
I'm assuming you have an automatic trans. You must use SPIII, which you can buy only from the dealer. I haven't seen it aftermarket yet. Mitsubishi and Kia use the same fluid, so you can buy it there as well. Part # from Hyundai is 00230-11000, and it lists at $5.54/qt
John Nance Parts Manager Terry Lee Hyundai 17665 Terry Lee Crossing Noblesville, IN 46060 |
Re: Re: hyundai sonata transmission
I hve changed me gearbox ,its automatic trans,But I thn fiilled it up with ATX and nw @ times if you put it on drive it wont move ,it only change to other gears so i will have to put on lower gear then put on drive later after it has driven for a while,but Its also rough when changing from lower to driver or to reverse.do you knw what might be the problem?
Re: Re: Re: hyundai sonata transmission
