Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-15-2005, 05:59 AM
workaholic2001 workaholic2001 is offline
Intake Manifold Gasket
My 92 350 blew the intake manifold gasket, with a pin leak in the front left. (while in front of vehicle ) Her is my delima, it has 250,000 miles on it. It runs strong, but needs valve stem seals (smokes on start up, and if I let it sit and idle). Heard of replacing valve stem seals, with the heads on. Should I bother or tear it down and re-build? Or buy one from a good friend at a salvage yard, with 67000 miles on it, and build my old one?
Respectfully,
Brian
Old 07-21-2005, 08:05 PM
fleettech fleettech is offline
Re: Intake Manifold Gasket
I did my stem seals with the heads on. just make sure you have a constant supply of air or you will be pullin the heads. with that kind of milage if you redo the upper end you could get alot of ring blow by.
Old 07-26-2005, 07:12 PM
kingdavidz kingdavidz is offline
i had the same problem except i blew my engine, i bought a retro for 1500 runs awsome as well
