Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 07-15-2005, 12:50 AM
Novaboy86 Novaboy86 is offline
Question what size wheels will fit on my Nova?
Hi, does anyone know if 15x8 wheels will fit the front and rear of my 1970 Nova without any rubbing? Thank you!
Old 07-15-2005, 01:19 AM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
On the front, Yes but I don't see a reason for having a 8 inch wide rim on the front, unless you just want it.
On the back, Yes, but you will need a 15x8 inch rim with 5 inches of backspacing. If you have an 8 inch wide rim with less, the tire will rub on the fender. If more, the tire will rub on the shock.
I run 15x8 inch Cragar rims on the rear of my Nova, with 5 inches of backspacing. I can fit a 26x10.5x15 drag slick on the car with zero rubbing, on a stock width rear end.
Rob
Old 07-15-2005, 09:36 AM
super68nova super68nova is offline
Re: what size wheels will fit on my Nova?
Rob
I have 15x8 in the front + rear same back spacing. 5". You can have 225/60/15 looks like stock car with wide meat all around.
Old 07-15-2005, 11:11 AM
Hello again, thanx for the info Rob! I have one more question. I found out that the wheels I want have 4 1/2 inches of backspacing. Do you think they will be ok, or should I just get 15x7's?
Old 07-15-2005, 10:25 PM
Robs71Nova's Avatar
They would probably work with 4 1/2 inch backspacing, but you may have either grind off, or roll up that inner lip on the inside of the rear fender.
It would work if you did that, but I doubt it would work as a 15x8 4 1/2 BS. It would be VERRRRRRY close, but I'm leaning towards no.
I have been known to cut half the fender off a truck to get bigger mud tires to fit, but I WOULD NOT recommend cutting on the Nova.
Rob
Old 07-15-2005, 11:44 PM
72_supernova 72_supernova is offline
check out www.novaresource.com they have a lot of good info
Old 07-17-2005, 04:53 PM
Dragnova70 Dragnova70 is offline
Lightbulb wheel fitment
I have a 70 with 15x10's on the rear that have 6.5 inches backspace. I am running a 28x13.5 m/t e.t. street tire and it works great!! I also have lowered the car 2" in the rear.
