Old 07-14-2005, 10:04 PM
bad3kgt's Avatar
bad3kgt bad3kgt is offline
Send a message via AIM to bad3kgt
Straight Pipe or High Flow Cat ?
Im wondering if i throw the straight pipe on my 3000gt, if it will screw anything up or if i should buy the randon tech High Flow cat from 3sx.....what do you guys think ?
Non Turbo btw
==--92 Mitsubishi 3000gt SL--==
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Unorthodox Underdrive Crank Pulley
Bomex Bodykit
18x8 Chrome rims
Old 07-14-2005, 11:56 PM
Hotshot8792 Hotshot8792 is offline
Re: Straight Pipe or High Flow Cat ?
Non Turbo btw
i'd get the straight pipe, and here's why
first off you wont mess up anything by eliminating your cat. In fact, i have 0 cats on my car and originally started with 2 precats and a main cat. Also, the straight pipe will give you less backpressure and better flow for more power.
If your state does not have emissions, you dont have anything at all to worry about as far as the straight pipe goes.
If your state has emissions, then you just simply need to make sure its a straight pipe you can bolt on the car and unbolt, so then you keep your cat and when its time for testing, all you do is switch the cat back on and then pull it back off after you pass your test.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-15-2005, 01:19 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ya, what Hotshot said ^. go with the straight pipe. it only takes 15 minutes to install. 4 bolts and 2 gaskets. quick replacement if you have to put the cat back in for emissions. also, a straight pipe will improve your exhaust sound, making it louder and a bit deeper.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-15-2005, 03:33 AM
Igovert500's Avatar
blue + red light magnet
+1 ^
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
