chev s10 horn & elec prob
Help - Chevy S10 1996 2.2
my first indication I had a problem was when my inside light(s) would not turn off after I turned off engine. I ended up pulling that fuse (2 or 3) to turn them off. Then I noticed by horn was not working and its fuse was blown. When I tried to replace the horn fuse it blew immediately. Whats up? I tried to check my horn relay and can not find it. Please help. So dangerous not to have a horn - what am I to do with all that pent up road rage? sarie |
Re: chev s10 horn & elec prob
Simple! Get a bicycle horn and screw it beside the mirror
I would try disconecting the horn first. They often rust out causing problems. Then plug in a new fuse. If it burns out again you'll have to look into the steering columb next. Not a fun job! The problem isn't usually anywhere else, although there is a small chance that you'll have to look at all the horns wire. For the mean time the bicycle horn or an air horn wired in is seriously legal in most places |
sounds like your problem is more your interior lights(courtesy)than a horn problem!horn and csty share the same fuse!
Check this out! I have a 94 GMC Sonoma when I press the horn I hear a relay buzzing under the dash at the same time my interior lights come on! Whats up with the wireing in this truck? Any suggestions?
P.S. (Buzzing) relay was swapped and still does the same thing but no horn. Fuse is also good.
daddy505, welcome to af. this thread is now over 2 years old. please refrain from posting in threads that are over 6 months old
. feel free to start a new thread if you like.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
