Old 07-14-2005, 08:49 PM
oopsbilly oopsbilly is offline
headlights won't turn off
have a 91 cherokke laredo HO. Started it in the morning and headlights came on without touching the switch. Won't go off now unless I disconnect battery or remove fuse!! Don't have daytime running as far as I know. There is something spliced into brown wire off of dimmer switch. Silver box screwed to underside of dash at left leg.PLEASE HELP. wiring harness is half stripped and I'm starting to get worried.
Old 07-14-2005, 11:01 PM
mrbill3's Avatar
mrbill3 mrbill3 is offline
Re: headlights won't turn off
How long have you owned this rig? Try this: Start the engine push the light switch in if it is out. If it is not out, pull it out and then push it back in then turn off the motor. Check the lights and post the results.
Old 07-15-2005, 10:19 PM
I've had this thing for 5 yrs. Tried what you said and no luck.
Old 07-16-2005, 12:27 PM
Saudade's Avatar
Saudade Saudade is offline
There's a light module under the dash near the headlamp switch that allows the headlamps to remain on after you turn off the key for about 30 seconds or so. Maybe it's toast now.
Old 07-16-2005, 03:30 PM
how do I find this? What does it look like?
Old 07-17-2005, 11:11 PM
mrbill3's Avatar
Check here: http://sio.midco.net/bmundahl/88xj-fsm.zip
or here: http://the-clarks.org/jeep/fsm/cherokee_service.zip
