Old 07-14-2005, 08:16 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Does a '93 have a Fuel Filter ?
I have a '93 Metro 1 L 3 cyl car.
I can't find the fuel filter in my Chilton Manual !
Does this car have a fuel filter?
If so - where is it?
Hard to change?
DoctorBill
Old 07-14-2005, 08:21 PM
DOCTORBILL's Avatar
Geo Metro Lover
Re: Does a '93 have a Fuel Filter ?
Sorry ! Found it in the manual...
These Chilton Manuals leave a lot to be desired.
Nothing in the Index or Table of contents about fuel filters!
Found it in the front in the section on Gen Info & Maint.
Sorry....
DoctorBill
Old 07-14-2005, 08:55 PM
DOCTORBILL's Avatar
Geo Metro Lover
Wow! I guess I have to retract my last reply to my own post....
I cannot find the fuel filter in the car! The Chilton manual says
it is in the Engine Compartment with a carbureted engine as mine is.
Simple 3 cylinder 1 L engine....
Nope - cannot find that sucker!
How big is it? Where the *&$($# is it!?
DoctorBill
Old 07-14-2005, 09:19 PM
serenity serenity is offline
My haynes manual says on a carburetor equiped 3 cyl. that it is located on the fire wall below the brake master cylinder. If fuel injected under rear of car left front corner of gas tank becareful either way. Good luck
Old 07-15-2005, 09:03 AM
mik13usa's Avatar
mik13usa mik13usa is offline
if it is a 93 it is NOT carbureted! It has throttle body injection or TBI .The fuel filter is in front of the drivers side rear wheel on the inside of the rocker area. it is held in by a couple of bolts that tend to break if the car has been in the snow a lot. The easiest way to do the job is to pinch the fuel hoses with vise grips or clamps and then remove the bracket holding the filter.
Old 07-15-2005, 11:33 AM
DOCTORBILL's Avatar
Geo Metro Lover
Re: Re: Does a '93 have a Fuel Filter ?
That sure looks like a carburetor sitting there on the lefthand
side behind the engine in the compartment !!!
I don't see any injectors behind each cylinder....
Where did you hear that '93's were never carbureted ?
DoctorBill
Old 07-15-2005, 03:47 PM
It looks like a carb, but it is acctually a throttle body injection unit. It sets where the carb would sit but it has an electronic injector setting on top. Unless your car came from Canada or some where emission standards are not as high.
