Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-14-2005, 07:52 PM
meteorshower14369 meteorshower14369 is offline
Send a message via AIM to meteorshower14369
Exclamation no compression
i have a 1991 eagle talon tsi , my boyfriend replaced the rod bearings, now it doesnt have compresstion and of course it wont start, does anyone have a clue why? he also replaced the starter first thinking it was that, so the starters good
Old 07-15-2005, 01:21 AM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
Sounds to me like it's time for a new boyfriend ... just kidding of course!
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 07-17-2005, 07:34 PM
macder macder is offline
Send a message via MSN to macder
Re: no compression
Is the crankshaft balanced?, where the bearings placed in hot oil before install?, Are the rod connectors overtighted? That's just a few questions i would ask of the top of my head. Replacing rod bearings is much more complicated then most people think, there is more to it then remove and replace. Many mechanics wont even attempt this kind of procedure, but rather replace the longblock.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 07-17-2005, 11:12 PM
RSLaser RSLaser is offline
What kind of shape are the rings in? That and the fact that if the timing wasnt right, he could have bent valves...were the rockers laying in the head after you tried to start it?
1991 Plymouth Laser RS
Only sat for a few years....
Old 07-25-2005, 02:38 AM
joemathews's Avatar
joemathews joemathews is offline
Re: no compression
If he replaced the starter after ruining your compression, it really is time for a new boyfriend--or at least one who doesn't try to be a mechanic.
Did he reuse the headgasket or replace it with a new one? Is the car blowing any smoke?
1996 Eagle Talon
