Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 07-14-2005, 07:03 PM
FDTT FDTT is offline
Ask your "dumb" questions about RX7's here
I know there are many many thread on here that have questions that are refered to as being dumb, or stuipd, pointles ect ect.
But if you are thinking about it then im sure there is also somone else out there who has thought the same thing. So id like to head about all the questions people are affraid to ask. It can be about anything at all. Dont be affraid to ask. And please dont flame anyone because you think there question is stupid or whatever.
If you dont have anything important to contribute then dont contribute anything.
Dont drive faster than your angels can fly
Old 08-26-2005, 01:21 PM
drewdeezee drewdeezee is offline
Re: Ask your "dumb" questions about RX7's here
Alright, I'll start. Does anyone here know of a good rotary engine mechanic in the Los Angeles area?
I have a 1986 base that needs a water pump and perhaps some additional grounding. Thanks in advance for any advice.
-Drew
Old 08-27-2005, 03:59 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
you can do that stuff pretty easily yourself
RX-7 TII
Old 08-29-2005, 12:54 AM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
ok n herres mine, why is it on all the sites i go to that have rx7 shit ALWAYS ALWAYS have a ground wire kit.. for the 86+ rx7's is the grounding kits in the from the fact. shitty or what?
Old 08-31-2005, 07:31 PM
Well 20 year old grounding straps that are exposed to the emelents and removal and instalation over that time tend to go to crap :P I run my own grounding cables on my car. There is no need to spend $200 for a grounding kit that costs no more than $50 to custom make to your application.
Old 08-31-2005, 07:37 PM
want a supra want a supra is offline
What dose it take to swap a 1987 turbo motor into a 1987 non turbo car?
Originally Posted by GForce957
Those who eat the Breakfast of Champions wear velcro sneakers
Old 09-02-2005, 04:52 PM
booricua booricua is offline
I ahve a 85 RX7 GSLSE is consuming fuel more than normal . When I check the engine oil level I notice fuel is getting mixed with the oil no problems with the car it starts and run good in any weather??
I am in MD any shop close that can help
Old 09-03-2005, 02:40 AM
Re: Re: Ask your
TII engine
TII wiring harness
TII ECU
TII hood (if running stock top mount)
TII flywheel
TII clutch
TII tranny
TII driveshaft and diff
Othere odds and ends but thats the just of it.
Old 09-03-2005, 02:42 AM
Re: Re: Ask your
Have this looked at ASAP. Fuel in the oil means that the rotors housings are getting washed out, meaning very little proper lubrication and possily a dead engine if not adressed soon. My guess is a stuck injector as it is an SE and has a 13B in it.
Old 09-05-2005, 01:04 PM
drftk1d's Avatar
Re: Re: Re: Ask your
Originally Posted by FDTT
TII engine
TII wiring harness
TII ECU
TII flywheel
TII clutch
TII tranny
dont forget the starter and knock sensor.
RX-7 TII
Old 09-06-2005, 06:39 PM
RevvRX-7's Avatar
RevvRX-7 RevvRX-7 is offline
Send a message via AIM to RevvRX-7 Send a message via MSN to RevvRX-7 Send a message via Yahoo to RevvRX-7
Why do rotaries backfire so much?
"Hand to hand. It is the basis of all combat. Only a fool trusts his life to a weapon."-Grey Fox -Gray fox (Metal Gear Solid)
"There is no good,there is no bad.Just perspective and opinion."-Squall Leonhart(Final Fantasy VIII)
"Love.. it is just an illusion which weakens and imprisons us."-me
Old 09-06-2005, 07:50 PM
All a backfire is unburnt fuel igniting in the exhaust.
The reason its so common on RX7's is because they run rich and hot. Those combined will give you a backfire and possibly the fireball everyone loves :P
Old 09-07-2005, 10:17 AM
RotorBalls RotorBalls is offline
Send a message via AIM to RotorBalls
How many pistons does an rx7 have?
Old 09-07-2005, 10:19 AM
ok on a serious note, anyone have a good link to a write up on how to remove the vac rack from an NA engine? I've seen brando's thread on teamfc3s but I don't know how it applies to the NA motor as his is turboed. I've been at a stand still for a couple months on my engine assembly because of this. That and I'm just lazy
Old 09-07-2005, 12:12 PM
drftk1d's Avatar
i thought you just take it off and cap the holes (wrong term i know)
RX-7 TII
