I need some help. Have a 98 Z71. There is a loud popping noise that comes from the front end. Doesnt always do it, just sometimes when i'm turning or brake really hard. Does it the most when turning in and out of my driveway. So far I have changed all four balljoints and all inner and outer tie rod ends. Idler arm and pitman arm are next, but they dont seem that bad and were just changed (supposedly by the dealership I bought it from) about 20,000 miles ago. This has been going on for quite a while and it is really aggrivating me.
Also the brakes have started to pull to the left under pressure now, the harder you push the harder it pulls. I need some advise please. |
Re: Front end Noise, Brakes
Maybe take it to a mechanic before you go blowing money on things that wont help solve the problem. At least have a professonial check it out to see whats wrong and then you can chose to do it yourself or let them fix it if the price is reasonable.
"Never under estimate the power of stupid people in large groups." 1997 K-1500 Silverado Vortec 350...125,610 and wounded HD chassis package Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers Poweraid Throttle Body Spacer Custom Ram-air Intake with K&N FIPK GEN II TFES Performance 3" Suspension Lift Dual Air-Horn Kit with Compressor Bed-Mounted 48" Hi-Lift Jack Cobra Laser Radar Detector 285/75/R16 Cooper Discoverer STT's 1/4 Mile 10/15/05: 16.43 @ 91mph |
Just a guess but it sounds like the front drive shafts could be worn out. Same sound as CV joints when they are bad. my .02c
I had the same popping noise and it turned out to be my left front drive axle, not to bad to change took about 30 mins...
