Old 07-14-2005, 03:42 PM
WH1PLA5H WH1PLA5H is offline
Need a stereo bracket
i'm looking for a double din stereo bracket kit that fits two single din units. any suggestions?
Old 07-14-2005, 05:21 PM
privatebean privatebean is offline
Send a message via AIM to privatebean
Re: Need a stereo bracket
i believe the double din factory bracket should hold two singles...mine is hold one and a tray..so the second radio should fit exactly where the tray does.
Old 07-14-2005, 06:21 PM
can anyone confirm this? has anyone tried stacking 2 single din units and mounting them on the stock bracket?
Old 07-14-2005, 09:39 PM
bump... somebody help!
Old 07-15-2005, 01:11 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
it takes 2 minutes to remove the stereo. why don't you try it. i don't mean to be an ass, but it wouldn't take much to try it yourself. if you have to do some modifications, they would only be small.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-15-2005, 01:08 PM
i have taken it out but i havent bought the two units yet. so i wanted to know if anyone has tried it
