Old 07-14-2005, 02:17 PM
toicy4ya's Avatar
toicy4ya toicy4ya is offline
Whats the difference between Ceramic & Semi-Metallic brake pads?
Thanks
99 Eclipse Spyder GS
Old 07-15-2005, 03:31 PM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
My understanding is that the ceramic pads dissipate heat better and faster than semi-metallic.
Old 07-18-2005, 07:30 AM
toicy4ya's Avatar
so in essence are they better?
Old 07-18-2005, 02:03 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Whats the difference between Ceramic & Semi-Metallic brake pads?
Yeah and more expensive.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 07-18-2005, 08:17 PM
Whathits14 Whathits14 is offline
From what I understand, ceramic pads are not great for street use, but more for track use with heavier breaking condidtions....
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 07-18-2005, 08:59 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
as i understand it
ceramic pads last longer and dont make as much dust
i think the braking is the same except that they dont fade after they get hot.
ceramic pads arre also noisey as hell most of the time. if you get them definately get new rotors at the same time
ceramics also wear out the rotors faster
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-18-2005, 10:11 PM
Gsx_hooptie Gsx_hooptie is offline
I agree with everyone, not that that helps much.
Neither are friendly to rotor life. Both make your car sound like a hooptie when you brake . Metal pads have a slight advantage in bite, ceramic pads dissipate heat better. High end track pads like Porterfields are ceramic. For your application, buy neither. Not even track-whores use their ceramic pads on the street. Well, maybe a few do, but anyway... try some kevlar blend stuff that's more streetable. Installing these with new rotors, as you are, is also a good idea.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 07-19-2005, 06:43 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I guess I'm a track whore, even though i've never been to the track....Or maybe I'm just a ricer.....
I use ceramic pads
I have to tell you that these are the best brakes I have ever owned. I don't know if it's the combination of the rotors/pad or if it's the pad themselves, but the braking is incrediable!!!!
No fade, no shudder, excellent pedal response and I can stop on a dime. I don't know if I will ever go with another type of pad. I am using the Akebono Ceramic pads and don't have any problem with noise or dust. They are advertised as having "Ultra-quiet, positive and smooth braking performance." I agree with that statement.
Anyway....I love these things, but as was said they are expensive.
http://www.dsmparts.com/customer/pro...&cat=13&page=1
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
