Go Back   Automotive Forums Car Chat > Ford > Contour
Old 07-14-2005, 01:50 PM
Grrldriver Grrldriver is offline
Unhappy running hot
I have a 1996 Contour and am a female so I always ask before i go to a mechanic. Mechanics in my area have a tendancy to screw over women. anyway.
My coolant light is coming on after about 20 minutes of driving. The coolant is filled above max and I had it flushed out about a month ago. No signs of leaks and the guy who worked on it said hoses were all good.
The engine doesnt "overheat" but it runs MUCH hotter than it usually does, especially when I have the air on. I have a feeling all I'd need is one good traffic jam to red line it. If i turn the heater on full blast, I can drive all over the place and the engine never gets hot and the coolant light never comes on.
Usually, the temp gauge sits between the N and the O, even when it's been running awhile. But if I drive for over 20 minutes with the air on, the coolant light will kick on and the temp will start creeping towards the A.
When Im idle, I can hear the fans kicking in.
I've heard everything from water pump to thermostat. What do you guys think?
Old 07-14-2005, 02:52 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
I4 or V6?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 07-14-2005, 03:34 PM
Re: running hot
its a v6
Old 07-15-2005, 01:41 AM
id start with the waterpump. Thats usually the culprit.
"The CEG Nazi"
www.contour.org
Old 08-16-2005, 07:36 PM
k_velev007 k_velev007 is offline
Re: running hot
what about if ita a I4? please,help me?
