Old 07-14-2005, 01:36 PM
sam43019 sam43019 is offline
ignition problems
ive got a 91 lumina 3.1L having ignition problems mainly no spark. car overheated on me got it home and would not start for me. started checking things out found a fuse that was blown labeled as DIS replaced it with a 10 amp fuses. now i have power on driver side of ignition module but none at the six prong plug on the passenger side and still no spark. any help would be great.thanks.
Old 07-14-2005, 10:11 PM
jonsonton's Avatar
jonsonton jonsonton is offline
Re: ignition problems
Did you use a test light to check for power. If so, bad move. Your dealing with a computer which mainly deals with 5 ref volts. If you have one use a multimeter.
First check all your fuses, a test light is recomende d here.
Then, with your voltmeter and your key on and engine off, check for 5 volts on the white wire leading to your ignition module. If you don't have 5V here check your powers and grounds on your ecm.
It's also a good idea, if you have access, to check for codes via a scanner.
Also check the knock sensor for 12 volts and a good gnd.
Do you have any spark or none at all?
Old 07-17-2005, 08:29 PM
ACEMAN8822 ACEMAN8822 is offline
You may have fried ignition module or a wire when it over heated.Only place i found that test them is Autozone.First Autozone had a bad tester.Found that out when their new icm off their shelf failed 2 test out of 6.Then i went to 2 other stores it passed.Crank sensor on mine is good too.But my ecm c5and c10 grounds are bad. I know they go Coolant temp,coolant level,maps and Egr but icant find exactly where they ground.I still have a no spark no injecter problem.Replaced Ecm with a new unit from Auto Zone but it too was defective off shelf with a power pin set in too far instantly popping ecm fuel relay fuse.3rd ecm from store looks ok but is still not working.Waiting for a Ecm i got off of Ebay for a lumina with the prom already in it.
