Old 07-14-2005, 12:24 PM
johnd4g johnd4g is offline
Electrical Problems... Help Please!
I've got a 2000 Camaro v6 w/automatic, 71,000 miles with an electrical problem that has got me puzzled. For the last couple of years I've noticed that when I put my brakes on, the lights will dim significantly and the RPMs will drop to almost nothing for just a second then back to normal again. The mechanic says the alternator checks ok but he couldn't fix the problem until something quits working. I recently replaced the battery and the problem is still there, but it seems more noticeable. Now it seems the same thing happens even when I just take my foot off the accelerator. I'd like to finally fix this problem before I get stranded on the road somewhere.
I sure hope someone can help!
Thanks,
John
Old 07-14-2005, 04:23 PM
jackmalone2001 jackmalone2001 is offline
welcome John!
I am NO expert!! But it sounds like a short. Maybe check the wires to your brake lights for continuity? (I say that because of your statement that it started with the brakes and then got worse...)
Anyway, I hope it is easily found and repaired.
good luck!!
Jack
before:
after:
Old 07-14-2005, 09:23 PM
ct91rs ct91rs is offline
Re: Electrical Problems... Help Please!
Sounds like a short or crossed wiring. When you say the rpm's drop, is it just the tach dipping, or does the engine actually slow down?
Old 07-15-2005, 06:58 AM
Thanks for your replies.
OK, I've got something to look for now.... a short or crossed wiring. Is this something a good mechanic should be able to find fairly easily or will it take alot of work.
BTW... the engine does slow down with the tach.
Thanks again!
