Old 07-14-2005, 10:13 AM
ActionWolf ActionWolf is offline
Send a message via AIM to ActionWolf Send a message via MSN to ActionWolf Send a message via Yahoo to ActionWolf
Exclamation Starting Problems #2
My 1992 Silverado Z71 is a champ in running contdition until yesterday... It is tempermental, the throttle/Carb or even the fuel line... I can start the engine one moment and when it runs; the gagues all over the dash are dancing back and forth, but another moment I need to run alcohol into the carb to start it, until it decides to quit in traffic causing me to pop the hood and give it another squirt... (this usually happens below 1,000 rpm.) I have a temoprary solution to stoping it from stalling........ I drive in as high a gear as safe for the engine and when i have to stop (traffic or lights) i throw it in neutral and bring my RPM to about 1.5 and it wont stall on me... I just dont get it cause even in mid drive it (the problem) will correct itself for a couple days. Or just one hour. And just pop back up again (the problem) out of the middle of nowhere... Can Anyone give me a pointer?
Old 07-14-2005, 10:29 AM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Starting Problems #2
how old is your battery?
Old 07-14-2005, 10:53 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
For one thing you are in the wrong forum. Second, when has your fule filter been changed last and injectors cleaned or at least some injector cleaner run through it ?
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
