Old 07-14-2005, 01:05 AM
justblaze justblaze is offline
those darn z24's
i've been browsing for a little bit now on the internet trying to learn a bit about performance mods. Now my intentions aren't to be any kind of street racer or what not, but i was lookin for some products that could help me still with speed, power, and performance (for example, just merging onto the freeway but having the immediate power to be able and pass infront of a speedy transport truck coming up fast as your merging lane is ending.
So i figure a new intake is probably the best way to get that little kick.
I've read about long and short ram (cold and warm) intakes. what i've picked up about them is basically they'll both do the same job since air is evenly circulated under the hood, therefore "intaking" the same temperatured air. So i guess my question is, where does the performance really come from then? cause i just can't justify it being in the tube really (except for an aluminum tube being lighter than the stock tubing/intake). So if i was to change just the intake filter, would that help give me that kick i'm striving for? if not, i've looked up intakes and noticed that k&n doesn't make intakes for the z24 (only the 2.2)...anyone know why that is?
i was also reading through one of those car buyers guide magazines and noticed that the breaking system for the 1998 cavalier was rated very poor. so what could be somethings i may look at to treat that?
final question for now, without having to lower my car, i was curious if a strut tower bar would help with turning?
thanks a lot for any input or advice you could give.
Old 07-14-2005, 07:51 AM
GotZ24 GotZ24 is offline
yeah, the power comes from the weight reduction. those damn rubber stock intakes are a lot heavier than the metal one you want to put in
use the search button!
Old 07-14-2005, 09:52 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: those darn z24's
well the Z24s and the 2.2s have the same intake box, so if you want to use a drop in fitler from k&n, just get the Z24. The way an intake increases performance is because its much less restrictive than the stock airbox/bong. On the stock air intake system, there are parts of it that get so small you could barely fit a finger inside of it.
The brakes, you can upgrade with some nice slotted rotors and titanuim brake pads. A strut tower bar will help a little with turning.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 07-14-2005, 03:58 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
you siad you heard 98's have brake problems, ive never heard that before but i do own a 98 and am having brake problems right now, kinda a coincidence i thought i'd comment on
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 07-14-2005, 05:39 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
It's not 98's. All J's are prone to brake problems. I've had em on the one I have and the one I had.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 07-14-2005, 05:49 PM
01Cavy 01Cavy is offline
Send a message via AIM to 01Cavy
Yep the rotors warped on my 01 about a month after the pads were changed. I use powerslot rotors and carbon metallic pads now. Haven't had a problem since.
2001 Toyota Celica GT
Check out my CarDomain at...
http://www.cardomain.com/ride/2493960
Old 07-15-2005, 10:41 AM
Why would a tube's weight, who's sole purpose is to flow air, factor into the ability to flow air? Why the hell would weight reduction factor into about a 1-2 pound difference? That's the difference between the driver taking a dump or not before they get in the car, it's nothing.
The power come from things like the filter and the actual flow path inside the intake. On a rubber intake there are bends, higher friction, and some form of restriction on the airflow (tubes is smaller, for example). These intakes also usually come with a K&N filter (or if you're smart, you get one for the intake) which is where a few extra ponies come out, as well.
Old 07-15-2005, 10:54 AM
nfg2184 nfg2184 is offline
He was being sarcastic.
-2004 Cavalier LS
Mods:
Weapon-R Short Ram, Shift Kit, Nitrous Express Wet Kit, Upper/Lower mounts.
Audio:
15" RE .SE sub to BRUTUS 1500, 6.5" RE components in the rear, Apline's in front, all to Pheonix Gold Profile, Alpine deck.
-1997 Sentra XE, 5-speed POS, commuter.
Old 07-15-2005, 12:34 PM
alright, thanks for the info. the stock tube piping which can cause more air flow restriction makes sence. it seems so common sence now.
anyway, could anyone direct me to a cheap aluminum build intake? i really don't want to spend crazy dollars for just a brand name product, which i'm hearing, pretty much does the same thing as a homemade one.
i plan on purchasing the k&n air filter seperatly.
Old 07-16-2005, 02:02 AM
-Jayson-'s Avatar
ebay is your friend
2009 Ninja 650 R
stock for now...
Old 07-16-2005, 03:05 AM
the problem with ebay is, i don't want to get scammed by buying something that doesn't end up fitting...or the buyer over charging me.... plus, since i live in canada, i don't know the additional taxes will end up costing when it's time to pick up the goods (i believe they're called tarrifs?)
anyway, i have a postup question:
I've noticed that some intakes claim that they'll only fit for Automatic transmission, what if i were to buy that product, but for a manual trany instead?
