Old 07-14-2005, 12:00 AM
justin_b31 justin_b31 is offline
Exclamation Freon alternatives
Ok did a lot of reading, 2-3 hours worth on the topic with lots of mixed results and contridicting information.
Basically I have a R-12 system that's out so I want to recharge it. Well I want to DIY, which requires a converstion ... however I heard that R-12 and R-134a are incompatible, requiring a flush and other steps possibly out of my level (vacuum, evacuation, etc) ... Additionally, I'm reading tons of stuff that says R-134a could damage my system due to higher compression requirements. Is this true? I'm doin this on a 92' Rodeo, 3.1L V6.
So I came across alternatives that claim compatibility with R-12 and similar compression requirements.
1) If my system needs a recharge, will I still have to have it evacuated and vacuumed by a A/C technician, if I stick with a compatible recharge kit?
2) From what I understand, the product Freeze12 is the only alternative that does NOT require use and installation of a barrier hose. Is this correct still?
3) Has anyone used the following with results similar to R-12 (as I also read R-134a doesn't work as good either) Free Zone, Ikon-12, R-406A aka McCool, Autofrost or Chill-It, Hot Shot aka Kar Kool, GHG-HP.
4) Anyone heard of Enviro-safe @ www.btt.org/ES.html and is it safe to use? Its not listed in EPA's SNAP list
Old 07-15-2005, 02:37 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Freon alternatives
there are three big problems to DIY A/C work.
1. skill - it is very easy to destroy the A/C system if you don't know what you are doing.
2. equiptment - recovery machines and gauge sets cost money.
3. its illegal to work with refrigurent without a EPA 609 certification.
however there is no big problem working on a discharged system. have the system recovered by a shop, do the repairs and retrofit, then have the system evaculated (1 hour minumim perferred for retrofits), leak tested, and charged
i wouldn't use anything not SNAP approved. R-134a is about 80% as efficenct as R-12. barrier hoses are required with use of R-22 or any blend with R-22. check http://www.epa.gov/ozone/snap/refrig...html#otherinfo for makeup to see if R-22 is part of the blend. personially i would just go with straght R-134a, blends can be troublesome, R-134a is more wide spread and easier to work with. also the pressure difference is not that great. also R-134a(or a blend) may require different hoses then R-12, not a barrier hose, just a hose compatible with R-134a. your vehicle may already have these hoses installed. if the hose is R-134a compatible, it should have a white stripe on it. you want to replace the Receiver/dryer, FOT(if applicible), and oil(depending on which refrigurent you use). you may also want to call your dealership/manufactior to see if any other parts need replaced for the retrofit.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 07-22-2005, 11:47 AM
public's Avatar
public public is offline
I used one of those converter kits from AutoZone 4 or 5 years ago on my 94 Cavi. It consisted of an adaptor for the valves and some new O-rings. The R-12 was gone due to a bad compressor. I installed the new comp. and drier, filled it with R134A and have been cool ever since. As for the hoses (I heard they would not work) they seem fine. If they blow this afternoon I got my money out of them. Total cost was about $150 for coomp/drier and $12 for the conversion kit. throw in som R134A and you are done. Easy. Good Luck.
Yes, I am retarded.
Old 07-23-2005, 09:16 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
r-134a and yes you do need to have it vacumed and recharged by a tech
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
