Old 07-13-2005, 10:20 PM
nicks420 nicks420 is offline
Question CAN I USE o2 sensor?
I plan on getting a testpipe for my turboed accord. The pipe does not have o2 bung in it. Can i get a bug welded on it and use my o2 sensor that is in my oem cat now and not have any issues. My car has two o2 sensor's, the other one is on the down pipe.
Old 07-19-2005, 09:38 AM
astroracer's Avatar
astroracer astroracer is offline
The O2 sensor in your cat relies on the heat to work correctly. Removing the cat will remove the heat generated by it. Sticking the sensor into a pipe that is running cooler will throw off the sensor and it will throw a code to the computer. Converter technology has improved leaps and bounds over the "old" stuff. You would be better off to leave the converter alone as I doubt you will see any real performance gain without a lot of computer trouble and extra dollars spent trying to iron out the problems...
The thing you have to realize is todays engines are designed to run with all of the systems in place. Unless you do a lot of mods to every system, changing just one will usually hurt performance and mileage rather then help it...
Old 07-19-2005, 03:28 PM
Re: CAN I USE o2 sensor?
i did install the testpipe with the o2 sensor. The turbo spools up so much quicker, it sounds a little better to. But the check engine light came on the next day. code 67: catalyst system below threshold. Is there any way to get around this issue? I like the performance it gives. I have to get the obd II emmisions test every year here in atlanta. Come on somebody, there has to be an easy hack for this.
Old 07-19-2005, 03:42 PM
TOMMY81 TOMMY81 is offline
Re: Re: CAN I USE o2 sensor?
I'm still trying to figure out what happened to 1989 grand marquis.
I had just changed the wires, plugs and cap / rotor because it was hesitating and sputtering at the red lights, well now its worse. Now it does stall at the red lights, unless I hold the gas and break at the same time, and it stalls when I come to a complete stop even before I can get it in park. Is this due to a faulty coil or TFI module?
Help! my car WAS running fine!
Tom
Old 07-19-2005, 03:43 PM
is that what is wrong with it? i need to replace the o2 sensor?
Old 07-19-2005, 10:13 PM
start a seperate post for that one dude.
Old 07-20-2005, 05:39 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
just get an MIL Eliminator, there's no way to get an O2 sensor to read within spec with no cat without one.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 07-20-2005, 10:36 PM
whats an MIL eliminator
Old 07-23-2005, 02:51 PM
drdisque's Avatar
its an electric resistor that replicates the signal of a working O2 sensor, search for MIL Eliminator on google.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 07-24-2005, 11:28 AM
yeah i found some on ebay. Well see if they work
