Old 07-13-2005, 09:30 PM
stevefx19 stevefx19 is offline
Send a message via Yahoo to stevefx19
difference between Z24 and 2.2
What is the difference between the Z24 and the base model cavaliers. I have a 2003 with a 2.2 ecotech is there a way I can make it into a z24, cuz my cousin had a z24 and it was way quicker than mine.
Old 07-13-2005, 10:34 PM
cficare68's Avatar
cficare68 cficare68 is offline
Re: difference between Z24 and 2.2
Different engine. And anything is possible with enough money
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 07-13-2005, 11:10 PM
94century's Avatar
94century 94century is offline
Different suspension and different final drive ratio. It is geared for quicker acceleration in the Z24.
Old 07-13-2005, 11:37 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Ok.. its ECOTEC... not ecotech.... and yes you can swap an LD9 into your car but personally i'd keep the ecotec. With a few bolts ons she's be pretty quick. Boosted ecotec's are up to 240Hp range right now and higher.
Hmm.... a z24 have a different suspenion. I think not, all J-bodys have the same damn suspenions stock. Why do you think all j-body stuff is interchangeable? And gearing... i think not also... They have the 4t40e auto or isuzu or getrag trannys. All 2.2's and 2.4's were geared the same but only differences were the location of the starters on the bell housings. I have a 4t40e in my 2.2... The LD9 is just a larger engine with more displacement and is DOHC instead of OHV....thus she is quicker..... please don't post mis-information.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 07-13-2005, 11:59 PM
94century's Avatar
Of course they are interchangable, what I am saying is the suspension is setup to handle better in the Z24. The anti-roll bars are a bit bigger, the spring rates are stiffer, etc. And when GM has a sportier version they do change final drive ratios. Example: In a GM car with the regular 3.8 (Grand Prix SE, Impala LS, Regal LS, Park Avenue) they have different final drive ratios than the same cars (Grand Prix GTP, Impala SS, Regal GS, Park Avenue Ultra) with the supercharged 3.8. They all have the same transmission a 4T65E, but a different ratio. Same with the Grand Am, the regular SE model 3.4 had a different ratio than the GT Ram Air 3.4, again same trans 4T60E, just different ratios. Same goes for the suspension setup in those cars. Also the Cadillac SLS with the 275 HP Northstar and 4T65E has a different fianl drive ratio as the 300 HP STSwith the same transmission, also the suspension is firmer in the STS. I am not talking about the 1st through 4th gear ratios, just the final drive ratio. Of course you can interchange suspension parts as well.
USS Carl Vinson CVN-70
1994 Buick Century
1988 Chevy Suburban C20 454
1989 GMC C1500 305
Old 07-14-2005, 12:05 AM
Lifted GMT-360!
Alrighty, nicely re-worded. I'm not going to get into a nit pick and argue about things... lol.
Old 07-15-2005, 11:28 PM
Re: Re: difference between Z24 and 2.2
Im going to keep the ecotec in my car , however what can I do to make it quicker like cold air intake....what else. Also I have a question about the tranny is there a way to check the fluid, what type of fluid does it take, and when I take the red cap off to fill it I can see a crank plate or whatever you want to call it but It wiggles a little, bit is that bad. I had a bit of trouble with my tranny so I replaced the IAT sensor and it was leaking where the coolant line goes into the radiator so tightened the bolt that seems to help but sometimes when I give it a lot of gas at once it seems like it doesnt want to shift. Should I put more fluid in it or what????
Old 07-15-2005, 11:56 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Just for some extra power I would get an intake and exhaust systems. If you have deep pockets, I would build the engine and get some boost. Nitrous is also an option. As far as checking fluid levels, I think I just have a dipstick under the hood labeled "Transmission Fluid" and if its low, I would just put more in.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-18-2005, 10:23 PM
I would just check the fluid with a dipstick like I have many times before with many other cars however the 2003 cavalier that I now own does not have a transmission dipstick. These are the sealed transmissions that have a red cap on top of the tranny, just to fill it but nothing to check the fluid level. That is what I meant when I asked how to check it. Any help would be appreciated
