Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-13-2005, 09:26 PM
bfarnsle bfarnsle is offline
Alot of talk about clearing codes?
Can anyone tell me how to do this? I do not have a manual for my car (a cutlass, 97.. supreme SL with 3.1 LV6).
If I remove the pos. battery cable, will that clear the codes from the PCM?
Do codes have to be cleared before the "service engine soon" light will go off?
Thanks,
brian
Old 07-13-2005, 09:43 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Alot of talk about clearing codes?
Ok Brain, your '97 has OBDII diagnostics and they can only reset codes with a scan tool. Some Diagnostic Trouble Codes (DTC) will reset themselves after a certain number of normal start cycles.
Some chain type auto parts stores will give a free diagnostic check so you can see whats wrong.
Some folks here can help discuss the problem after you get the free check.
Old 07-14-2005, 01:07 PM
Re: Re: Alot of talk about clearing codes?
Here are the codes I have:
This evening, I went to Autozone and hooked up the car to their computer. The codes returned were
P0121 - Throttle position sensor (I replaced this after seeing this code)
and
P1133 - H02S Insufficient Switching Sensor 1 / Bank 1 fuel control shifted lean (FAOSC).
I have replaced the TPS. Have not rescanned since. I have no idea what the P1133 is talking about. The oxygen sensor (pre cat) has been replaced also.
Old 07-15-2005, 08:08 AM
Re: Re: Re: Alot of talk about clearing codes?
and
--For those who care... I went to Autozone last night and they let me clear the codes out of the PCM using their tool (they won't do it, but they will let you). After this, the service engine soon light went out and has stayed out thusfar.
Thanks for all the help!
Old 07-15-2005, 09:52 AM
Jeremy86 Jeremy86 is offline
Send a message via AIM to Jeremy86
Glad it's fixed. That was odd. Sometimes it says something is wrong w hen there really isn't.. or it is so insignificant. I'll have to remember that if something like that happens to me!
Aka 93 Cutty
Working on my next project: A 1986 Honda CRX. Little beater with lots of engine
Car Audio Freak
http://www.sounddomain.com/ride/613185
Old 07-15-2005, 08:27 PM
AF - Advisor
The #2 heated O2 sensor on my '97 Bravada kicks out a code every year or so, I reset it with my scanner (I ain't givin'em free advertize) and wait till next year.
