Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-13-2005, 06:55 PM
stuckey77 stuckey77 is offline
4 Wheel Drive Problems
I have a 1994 Dodge Ram 2500 V10. Today I put it in 4 wheel drive and took it for a drive. When I put it back into 2 Wheel the 4 Wheel drive light stayed on. I put it back into 4 than when I went to switch it back down it made a grinding noise and vibrated the shifter. I used it like i have before. Can anyone help me? It would helpful.
Old 07-13-2005, 07:11 PM
sharter sharter is offline
Re: 4 Wheel Drive Problems
Is it still stuck in 4 wheel?
Old 07-13-2005, 07:43 PM
The shifter shows it is in 2 wheel but the 4 wheel light is on.
Old 07-14-2005, 06:10 AM
Re: Re: 4 Wheel Drive Problems
Maybe you can try this to see if it is still locked in 4 wheel. Jack up the front end and see if you are able to turn the wheels. I would say that if in 4 wheel you should feel some resistance. If in 2 wheel I think more freely maybe? And if the light is still on maybe it is still in 4 wheel and there may be a linkage problem. I'm just kind of guessing. Have you tried to move the shifter back to 4 wheel and then back again?
Old 07-14-2005, 06:52 AM
wilwith1l's Avatar
wilwith1l wilwith1l is offline
First thing you have to do is find out if it is actually in 4. If it's a manual you can do what sharter said, and the wheels will not turn if it is in gear in four. If it's an auto, put it on stands, and turn the front drive shaft. if the wheels turn it's in four. IF it is actually in four trace the shifter rods to the T case to make sure they are allright. IF it isn't in 4 but the light stays on, it's probably a problem with the switch.
Old 07-14-2005, 09:27 AM
When I put the shifter in 4 and tried to move it back it made the grinding noise.
Old 07-14-2005, 01:20 PM
I'm not sure but it sounds like a gear problem. Maybe take it to a transmission shop. They can better diagnose it or give them a call.
Old 07-14-2005, 04:03 PM
thank you all for the help. When I started up this morning the light was off. and it feels like it's in 2 again.
Old 07-16-2005, 05:41 AM
Blylock Blylock is offline
i would address this issue. i agree it could be your linkage sticking or not adjusted, or the switch sticking. im not sure if you have a vacuum forced front axle on that year, like i do (CAD), but they are known to fail. first thing i would do is get under there and spray your linkage with PB blaster or some high quality lubricant, and with the truck off, move the shifter from 4h to 2h a bunch of times. next check the level of your xfer case fluid, and condition of it. if its brown or rusty colored, get it replaced. the grind is caused by the xfer case not being fully engaged in any gear when shifting it.
1998 Ram 1500 SLT 4x4
5.9L
Dynomax Performance Dual Exhaust
KN cold air intake
Bosch +4 Platnum Plugs
180 Degree Thermostat
I would suggest to anyone with a Ram to convert to a performance exhaust, especially if towing alot.
Old 07-16-2005, 12:31 PM
Hey Blylock.
Why do you suggest the performance exhaust and what about the cold air intake? Does all of this save on gas? Where is the cold air intake installed?
Thanks.
Old 07-16-2005, 12:34 PM
Re: Re: Re: 4 Wheel Drive Problems
Originally Posted by sharter
Hey Blylock.
Thanks.
Also I would like to convert to dual exhaust. What about the cat. I only have one. Would I have to install one for the other exhaust as well?
Old 07-17-2005, 05:18 PM
Re: Re: Re: Re: 4 Wheel Drive Problems
sharter, all i do is tow with my truck. a 3500lb boat to be exact. i converted to the cold air intake and noticed little difference overall. not to mention KN specs a 12hp gain for my model truck and motor after install. i converted my exhaust after cat to a dynomax dual performancve system. i may not have gotten the HP increase i desired, but the throttle response and torque increases amazed me, while towing. and the sound, well it sounds like a truck. for the price of running true duals, in which i would install headers to do it, its not worth the cash. it cost me 120 bucks for the 2 pipes and muffler for the conversion, your looking at 800 minimum for the true duals.
all i am saying from experience, the dual exhaust mod i did was the most noticable towing.
5.9L
KN cold air intake
