Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-13-2005, 06:40 PM
bkahn55 bkahn55 is offline
Rich Fuel Bank 1 & 2 Error Codes
I need some help here. The fuel pump on my 96 Tahoe recently went out so I replaced that with a new one from Carquest. Immediately after I changed the pump I got a SES warning. I pulled the Neg. cable to reset the system thinking it was just from replacing the pump. The SES came back on so I went to Advance Auto to find out what the error was. I have two errors, both are for Rich Fuel on both banks. They had no idea what could be causing it. He reset the SES and it came back on after driving for about 10 miles. I talked with a mechanic friend and he seemed to be at a lose too! I don't want to start changing O2 sensors or Mass Air Flow sensors if I don't need to! Thanks for the help!
Old 07-13-2005, 07:27 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
What this means is too much fuel or not enough oxygen is being dumped into the compustion chamber.
Could be caused by excessive fuel pressure from the new pump (may be wrong pump for the truck)
Since this started after you replaced the pump, I would check fuel pressure first.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 07-13-2005, 08:44 PM
The fuel pump is an exact replacement of the fuel pump that went bad. Both came from Carquest. Is it possible that the Mass Air Sensor was bad before the new fuel pump but there was no error because I wasn't getting enough fuel before. Now that I am getting the proper fuel volume the lack of oxygen is evident?
Old 07-15-2005, 03:49 PM
Re: Rich Fuel Bank 1 & 2 Error Codes
I have verified that the fuel pump is the correct one and the fuel pressure is also correct. Is the next thing to try replacing the Mass Air Flow Sensor? The truck runs fine except that it seems to have reduced fuel economy and the engine light stays on for the rich fuel error. Any advice??
