Old 07-13-2005, 06:13 PM
new2geo new2geo is offline
PCM location???error code 42
Any ideas? I have a 94 XFi and drove to the Post Office, got back in car....cranks but doesn't start. no spark at coil. Code 42 says Crankshaft sensor...but more than likely is it the PCM?? Where is the PCM located anyway? Thanks in advance to all....
Old 07-13-2005, 09:26 PM
serenity serenity is offline
Re: PCM location???error code 42
Do you mean pcm or ecm Emission control module? A code 42 is a crank angle sensor and that says to check for a faulty connector or circuit. also an improper air gap in the distributor. The module in your distributor I believe goes to the ecm so there could be several potencial problems. The ecm unit is the silver box located unde the dash near stearing collum. I also seem to recall reading some where that a connector to the ecm can get loose and cause intermintet starting failers and cleaning the proper connector will sometimes fix the problem. Maybe some one here can give you better details . Good luck
