Old 07-13-2005, 05:46 PM
vali vali is offline
cluster panel light
i have a 2002 cavalier. it appears that one of the bulbs in the cluster has blown. the right side of the speedometer is dimmer than the left side. can i just replace the bulb or does the entire cluster have to be replaced?
Old 09-04-2005, 12:10 PM
quake61's Avatar
quake61 quake61 is offline
Re: cluster panel light
the only pain in the rear thing to do is removing the dashboard
after that u just replace the light bulb and ur done
look at this thread made by classicrock junkie it explains everything u need to know to safely remove front dashboard
then u remove cluster and replace bulbs
http://www.automotiveforums.com/vbul...d.php?t=321030
good luck
