Old 07-13-2005, 02:20 PM
DjEarth DjEarth is offline
Buzzing Noise Over Engine
Just started yesterday, overtop of the engine idel I can hear this buzzing noise. I know about the fuel pump buzzing and it doesn't seem to be quite the same noise. With acceleration the buzz gets higher..then when you slow down it slows down as well. Everything is running fine, no starting problems. My friend said it may be the alternator starting to go. Any ideas?
Old 07-13-2005, 03:48 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Buzzing Noise Over Engine
is it a high pitched whirring noise?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-13-2005, 04:16 PM
Yes it is. But it isn't a extremly over powering noise.
Old 07-13-2005, 05:41 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
PCV Valve?
Old 07-13-2005, 09:48 PM
BlazerLT's Avatar
AF -Advisor
might be, easy to check and replace.
Open the hood and have a listen to pin point it.
Old 07-14-2005, 06:28 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Might also be a water pump bearing going south on you. Have that looked at too if you are not mechanically inclined. If you are mechanically inclined, it can be checked by removing your serpentine belt temporarily. Grasp the fan by one of it's blades and turn it. The fan should turn the pulley behind it. If the pulley turns smooth and even then your problem is somewhere else. If it binds, feels clunky or makes a grinding noise or feels rough when you turn the fan, well, you found your culprit.
Other possibilities are bearings in the idler pulley, tensioner pulley and power steering pump. Since it is hard to describe the sound you are experiencing in text, check all of the above. Power steering pumps tend to start making noise when they are low on fluid, so check that too.
Your friend may also be right about your alternator. One way of checking is to take a 12" extension or a long screwdriver and touch it to the suspect part on a solid part of it's body. Place your thumb over the end of the screwdriver handle/extension and rest your ear on your thumb. Wherever the hum/whine gets louder, you found your part that's busted. Needless to say, be very careful when using this technique, you're putting tools and your head near moving engine parts. I used this technique to pinpoint a bad bearing that was making a whining noise in my seprentine belt tensioner. $9 later, I had a new plastic pulley in place and the problem went away.
EDIT: In my experience, sometimes a water pump bearing going out will sometimes sound like a belt squealing. A set of needle bearings on an alternator going out will sometimes make a low moan to a mid-range "Woooooo" sound like a police siren. Idler and tensioner bearings will grind and clunk. Power steering will whine and rumble when low on fluid or the pump bearings are shot, the sound getting worse/louder when the wheel is turned with the vehicle at rest. (Second thoughts always plague me!)
Old 07-14-2005, 08:16 AM
czm400r czm400r is offline
Mine does the same ever since I had the Alternator replaced. I need to look into where the whine is coming from. Its bad enough I have a whine in the house, I don't need one in my garage.
Old 07-14-2005, 08:21 AM
lou S. lou S. is offline
Remove the belt from your alternator and see how easy it is to spin the pulley. If it takes a lot of effort your may have found the source of your whine. When those bearings go and lock up you won't be able to turn the pulley.
Old 07-14-2005, 10:43 AM
89BLAZER4ME's Avatar
89BLAZER4ME 89BLAZER4ME is offline
I am no mechanic, but mine kinda makes the same noise, and it seems to only do it when the A/C is on...so I think it could be my compressor.
Old 07-14-2005, 10:49 AM
herkyhawki herkyhawki is offline
Remove the belt completely and then start and run the engine for a short time. This will isolate all belt driven accesories so you know if your chasing an accesory or a system on the engine.
Yep, a lot of the accesories that are driven by the belt contain inner bearings that can go out----finding which one it is is sometimes more difficult than actually replacing the component.
Old 07-14-2005, 02:12 PM
We just replaced the waterpump a few months ago so I am sure it's not that. Gonna pick up a PCV valve this afternoon and start there. Most likely it has never been replaced.
Old 07-14-2005, 02:18 PM
Big Tall Dumb Ass
PCV valves are cheap, but you might want to pin point your problem before replacing parts that don't need replacing.
Old 07-14-2005, 02:40 PM
Checked it last night, my mechanic friend thinks it should be replaced and that it probably never has been.
Old 07-16-2005, 08:39 AM
BlazerLT's Avatar
AF -Advisor
Yea, I would replace it, they should be replaced every 40k.
