Old 07-13-2005, 01:20 PM
slim4tx slim4tx is offline
Starter troubles
I have a 1995 K1500 and receantly replaced the battery. When I hooked up the new battery the starter started spinning with out the key in the ignition. I later pulled the IGN B fuse from under the hood which solved the problem and the truck starts and runs like normal but apperantly the IGN B fuse also runs the AC and power windows. Could anyone tell me if I have a blown relay or short in the wiring some where and how I can fix it. Any help would be great because I'm really confused. Thanks.
Old 07-15-2005, 09:04 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Starter troubles
Do you have a remote starter on it? Sometimes remote start systems will activate when power is disconnected and reconnected.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
