Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 07-13-2005, 12:52 PM
joedangerus joedangerus is offline
'95 Mark VIII remote Entry
I bought a '95 Mark VIII. I have figured out the code for the keyless entry (found it on the trunk support arm) and want to add a remote entry feature. I purchased an after-mark remote specific for the car and followed the instructions but nothing is happening. Is there a way of telling if the car is equipped with a remote sensor device? Appreciate the help.
Old 07-18-2005, 01:08 PM
Towncar's Avatar
Towncar Towncar is offline
Damn, this place is dead lately..
Try the lol folks too....
-Steven
1996 Town Car, Cartier
Old 11-16-2005, 10:20 AM
BlackiceLSC BlackiceLSC is offline
Re: '95 Mark VIII remote Entry
just so I understand, you bought a key-fob that is specific for the 95 Mark VIII, and programmed it properly? Did you use the little wire end behind the glove box?
if so, perhaps the remote's battery is dead. It uses 2 or 3 I think...they are like watch batteries.
also, be sure you definately have the right remote. The 93-96 use the older "long" remotes(cant recall fcc#) the 97-98 Mark VIII's use the newer/smaller little "square" remotes. If your new remote/fob is a little square, then it it is the wrong one. also, many of the newer little "square" ones have a on/off switch titled "memory recall". If your fob has that, it too is the wrong one.
other than that, it should work, if you follow
THESE directions.
let us know, ok?
Old 11-17-2005, 11:33 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
It sounds like you bought an aftermarket remote and are trying to program that to the factory receiver - Why not get a FACTORY remote for the car, so you know it works?
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
