Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 07-13-2005, 11:42 AM
djK1 djK1 is offline
Question what size injectors???
Ok, not to give you a long background story, but I tore open my oil pan, broke a motor mount and bent my shift linkages playing chicken with an abnormally high man hole cover...I lost. So since I have to do some work to my car, I am going to install my turbo set up that has been sitting in my garage for about a year and a half, I'm a procrastinator. So I have a JDM B16A1, 255 walbro fuel pump thus far and I'm going to need some injectors, I am going to get some MSD injectors because I can get a hook up. So with that said, what size injectors will I need? I am aiming for 1 bar / 14-15 lbs of boost (Yes I'm rebuilding my bottom end with pro crower rods and pistons I haven't picked out yet). I'm also getting a Vector X intake manifold and my e-manage can control 2 sets of injectors. Should I go that route, 2 sets of injectors? If so what size injectors will i need for that? Should I post this question in the tech forum?
what I have/going to get
JDM B16A1
turbonetics t3/t04b
oversized f/m intercooler
msd 6a ing. system
GReddy e-manage full system, Injector & Ignition controls
other stuff that really doesn't pertain to this question and too long to list.
djk1
Si-leeper: "Take'm by suprise"
Old 07-13-2005, 06:21 PM
londa hover londa hover is offline
Whats the cfm rating on your turbo?
Old 07-14-2005, 08:00 AM
Not sure, the turbo has been sent off to be rebuilt, but I haven't talked about the specifics yet. I'm aiming for about 300hp at the crank, I would love to have 300hp at the wheels, but I want to be practical and reliable. what do you suggest for this set up since I am having the turbo rebuilt I should be able to size the turbine to my specs.
Old 07-14-2005, 04:10 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: what size injectors???
I did a huge write up on this along time ago...ill see if I can dig it up.
2002 Acura TL Type S
1991 Honda Crx Si
Old 07-14-2005, 04:20 PM
Choosing the right size Injectors
1991 Honda Crx Si
Old 07-18-2005, 01:41 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
dont go 2 sets, just get bigger and go single set
too complicated, get dsm 450s, they are good for 300whp. and if the turbo is a good size then you dont need to go 14psi to reach 300whp.
Team Lonely Drivers
Old 07-20-2005, 11:47 AM
Thanks, that was what I needed!
Old 08-11-2005, 04:02 PM
problemhatch problemhatch is offline
Witht the right tuning you can easily put down 350 on pump gas to the wheels w/14-15 psi. watch the injector duty cycle. I would go with rc 550 saturated to be safe.
