Old 07-13-2005, 11:16 AM
zeppelin2112 zeppelin2112 is offline
Send a message via AIM to zeppelin2112 Send a message via MSN to zeppelin2112
Dashboard vent problem
recently purchased a 93 s10 Blazer, and have a problem where the AC and Heat only come out of the floor and windshield vents, nothing from any vent on the dash... Any help you guys have would be great... thank you!!!
Also have a problem with 4-lo. Tried to switch it normally, and the light blinks amber for some time and goes back to green... Tried it in neutral, switching to park while it's blinking, and still nothing. Really no big deal, as i'll probably never use it... but it's just another thing that doesn't work, and i'd rather it did. =P
Old 07-13-2005, 11:49 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Both problems most likely related to bad vacuum lines.
Check all your lines from the manifold to the vacuum cannister, and
the line from the cannister to the transfer case.
Old 07-13-2005, 01:26 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Dashboard vent problem
Like Mike says, check the lines from the source all the way down to the other end of the line, not just to see if both ends are attached. On my 89 S-10, there was a vacuum line that looped around the base of the distributor that actually had a hole burned into it where it touched the distributor, and resulted in a bunch of problems.
Old 07-14-2005, 04:26 PM
I know it's probably not a question you guys want to answer, but i'm not too experienced with cars, let alone something big, like my blazer... Where would I find the vacuum canister? I've searched through my Chiltons Guide, the internet, etc. Just a quick description would be so great... :/ sorry.
Old 07-14-2005, 04:30 PM
Big Tall Dumb Ass
Look for a 6 inch black ball on the passengers side of the engine compartment and see if the vacuum lines are connected to the ball.
Old 07-14-2005, 05:05 PM
ok... traced all the lines, only to find this
http://img162.imageshack.us/my.php?image=img11175lg.jpg
(sorry, couldn't figure out the weird forum html to post the picture in the box)
am I missing some lines that should be connected to these points? Otherwise, the lines look like they're all intact...
Old 07-14-2005, 05:41 PM
Big Tall Dumb Ass
It sure looks to me like you are missing some lines. From what I can see in the photo, 2 out of 3 lines look disconnected or missing.
Old 07-15-2005, 11:57 AM
Thanks for the advice... Found one hose that plugged into the smaller point, and the bigger hose plugged straight into the engine... also fixed my cruise control. You guys are great.
Old 07-15-2005, 12:07 PM
Big Tall Dumb Ass
Another happy customer! You gotta love it!
