Old 07-13-2005, 09:22 AM
Prempt Prempt is offline
2.5L Burning oil - going to remove cylinder head. Help please.
1987 Chevy S-10 2.5L
I am burning oil. I go through a lot of oil and I have a very very minor leak (not anywhere close enough to equal the amount of oil I lose). When I go to put oil in, I will burn off a lot of white smoke, after a while though there is no smoke yet I still will burn oil till it runs dry or near dry. I am going to remove the Cylinder head (Or at least try). After reading the "How to" in the Haynes manual, I am a little scared just because it seems like a lot of work.
My questions are -
1. I have standard garage tools. Will I need anything special to do this?
2. While I have the head off and everything else that I need to get to the cylinder head, is there anything that I should replace that isn't too costly?
3. If it's not my cylinder head, where else could the oil be coming in at?
Thanks in advance.
Old 07-13-2005, 11:08 PM
drdd's Avatar
drdd drdd is offline
Re: 2.5L Burning oil - going to remove cylinder head. Help please.
http://www.automotiveforums.com/vbul...d.php?t=283211
http://www.automotiveforums.com/vbul...ghlight=autorx
My questions are -
Thanks in advance.
Old 07-14-2005, 12:08 AM
whitetrash982 whitetrash982 is offline
Send a message via AIM to whitetrash982
far as burning oil - on high mileage cars , the 2 big things that will cause it to consume alot of oil are either the valve seals or the piston rings , of which either could be wrong if your has alot of mileage , as for tools , im honestly not familair with the engine , sorry
Old 07-14-2005, 02:07 PM
rstroud rstroud is offline
Mostly just regular tools will be all that you need with the exception of a torque wrench to re-install. If you remove the valves, you will need a chevy valve spring compressing tool. Not expensive. Be certain you follow the correct re-torque sequence in the manual. If you don't, you can crack the heads.
