Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-13-2005, 09:35 AM
mrmetrx mrmetrx is offline
Loud screech when I start my engine
I have 1999 Toyota 4Runner SR5.
When I start my engine in the morning it gives off a loud screech for about 3 seconds then its gone. It only happens after my truck has been off over night. Im pretty sure its the belts but I know very very little about engines. Any suggestions????
Thanks
Old 07-13-2005, 09:52 AM
1990 Hilux surf 1990 Hilux surf is offline
It is your belt(s). Inspect your belts. See if there is a glaze (shiny), or see if it is loose at all. Belts squeel more when they are cold. Even a bit of oil on them will make it do it. A/C belts are awesome for doing it since A/C compressors work the belt more than anything. Is the A/C on when you start it?
Old 08-09-2005, 12:49 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Re: Loud screech when I start my engine
Originally Posted by LearysGhost420
If you want your a/c to last almost 50% longer......make sure the a/c is OFF before you start the engine. Turn a/c off before turning off the engine also. Common sense
Making sure the AC is OFF before starting the engine is better for the engine also. Starting the engine puts more stress and wear on the engine than almost anything else.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 08-22-2005, 02:15 AM
EGilson0606 EGilson0606 is offline
see how tight the belts are, you may just need to tighten them up.
