Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 07-13-2005, 08:29 AM
numedpick numedpick is offline
Blower speed (5) not working
On my 2001 Montana, I have front blower speeds 1-4 working but 5 (highest) does not. Is this also the resistor?
Old 07-14-2005, 11:20 PM
GregA's Avatar
GregA GregA is offline
Re: Blower speed (5) not working
I believe you have a choice of two components, assuming the wiring and switch are OK.
1) 30 Amp Circuit breaker for the Hi Speed Blower (found at bottom-left in the fuse panel inside the van). See here: Fuses
2) Relay for the Hi Speed Blower. My manuals say it is located on the Blower Motor Resistor Module, so you MAY have to replace the entire module, unless the relay can be replaced on its own.
I would swap around the Circuit Breakers in the fuse panel FIRST (assuming they are the same part) and see if the problem moves with the breaker. If that has no effect, its time to pull the resistor assembly loose and give it a look.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 07-16-2005, 11:45 AM
Re: Re: Blower speed (5) not working
Take Care,
Thanks for the help. I switched the 30 amp circuit breakers with no effect. I too suspect the relay but had been unable to find it based upon the jpg files seen of it on the internet. It makes sense what you have said. I had been putting off pulling the resistor module but will let you know if that is the fix.
Thanks,
John
Old 07-17-2005, 04:31 PM
The blower motor relay is on the resistor module in this vehicle. Does not appear you can replace one without the other. For anyone looking in the future it is AC delco part number 15-80552
and Carquest or Standard Motor parts number RU-50 is listed as aftermarket replacement. Hope that fixes mine. I have ordered part and will see.
