Old 07-13-2005, 08:59 AM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
Obd II Emissions Question
The mods that I will will be doing, which will be one at a time due to fund allocation issues, due to weak ass government pay. but hey. I didn't join for the money.
I am curious as to how it will effect the emissions test, since they hook me up to a computer instead of the old tail pipe test. In one more year it will be a classic and I will not have to donate to the government slush fund.
What mods will start affecting the emissions of my baby?
I am still in the first stage of the 2g mod process.
Thanks in advance for you responses.
1997 Black Eagle Talon Tsi AWD
K&N FIPK
The rest is stock but not for LONG!!
Old 07-13-2005, 09:47 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Obd II Emissions Question
I'm too lazy to check your profile and see where you live, but I will tell you about PA's OBD-II emissions.
There is a visual inspection of the exhaust for leaks, presence of a cat, muffler, etc. They never even bothered to open the hood. They tested the gas cap and then plugged me into the computer.
All the OBD-II emissions machine does is verify that the emissions sensors are "ready for testing." This includes such things as O2 heater circuit, EGR valve, etc. It also verifys that there are no stored CEL's.
Here is where it becomes fun. Eclipses have this random problem of resetting the status of the monitors every time the car is turned off. They should not do this. The monitors should only be reset when the power to the ECU is lost. When the monitors are reset the ECU has to go through certain "drive cycles". The ECU drive cycles are almost impossible to complete and absolutely rediculous.
Example drive at 40mph and 50% throttle for 20 minutes, decelerate to 10mph without using the brakes. Accelerate at 10% throttle to 55mph and drive for 23 minutes, decelerate to a stop using the brakes and turn off the car. Well duh, turning off the car is what resets the monitors.
Anyway, if your car has this problem, you have to take it to the stealership and pay them to "force" the monitors into the readiness state so the car will pass emissions.
Two years ago this cost me $136. I did read on tuners that someone was charged almost $250.
Anyway, to answer your questions, unless you remove the cat and replace it with a test pipe, you will be fine. Mine passed with all of the mods in my sig, except for the EVO III.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-13-2005, 03:42 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
and that's why I'm glad I have a 95 Its obdII but they think it's obdI
If you live in a very rural state such as Wyoming or New Mexico etc. I wouldn't worry too much about restrictions but if you are in a big city Houston, Los Angeles, New York etc. it might be an issue
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 07-13-2005, 05:21 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
ha ha ha... if ya lived in MN all ya gotta do is buy tabs and your on your way tra la-la la-la......
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 07-13-2005, 11:12 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Re: Obd II Emissions Question
that applies to me, lol,
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-14-2005, 12:26 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
i just paid 450 to get my spyder smogged...
the guy closed the door and i got it back in a couple hours complete with the smog cert... lol
Old 07-14-2005, 12:29 AM
Whathits14 Whathits14 is offline
well if you are in CA, its a little harder...did you recently purchase your car? If so, get it smogged now so you will have 2 full years before you have to worry about emissions...but the mods that will affect your emissions are different cats, exhaust sometimes, I expect a new turbo, modifications to your fuel system.........haha getting rid of the cat because it sucks ass anyways lol....if you do, get a test pipe flanged so you can bolt a cat back on when you do go for emissions....
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 07-14-2005, 12:30 AM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
No emissions tests down here in Florida! Wooooo lol
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 07-14-2005, 12:41 AM
I am in Georgia, we have to test once a year.
Old 07-14-2005, 12:50 AM
o wow...well I dunno how badly all that stuff will affect your emissions but I'm sure theres a way....florida doesn't have tests?!?!? you bastards get all the good stuff....94 octane and no smog checks.rrrrrr
'95 Talon Tsi
