Old 07-13-2005, 05:39 AM
ridinglow ridinglow is offline
Question How Low Can I Go With....
Yo i got a question for anyone that may know the answer how low can i go in the resr with 14 inch stock wheel(1989) with 205/75R14 tires and how about the front??
Question #2 how low can i go in the rear and front with a 15 inch stock wheel (1997) with 195/60R15????
A LOT of help would be great and thanks!!!!
Old 07-30-2005, 05:15 PM
brightdim03 brightdim03 is offline
Re: How Low Can I Go With....
the only thing you can do is lift the suspension about 3 inches and find a wheel well enlargement kit, take a look at the specs for a ZR2 arangement (GMtrucks.com should have the measurements) and use it at a template
Old 07-31-2005, 09:50 PM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
I did 5in in front w 3 in spindles and 2 in springs the tires rub in hard turns and on very bad bumps I also did 5in in rear with blocks and bottomed out on bump stops on the bumps this is on a 84 s10 ext cab on my 92 sonoma ext cab I have done 2in front and 2 in rear with 235 60 15 tire on aftermarket wheels and it looks tuff and handles great and rides better that stock but I do get tire rub on u turns only on front
Old 08-01-2005, 05:08 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
im 5/6 lowered on 20's
Old 08-01-2005, 10:40 PM
bignasty50 bignasty50 is offline
i had a 98 s10 with the same tire height as your set up of (195/60R15) but with a 16 rim. the tires were a little smaller but had the overall height as yours. mine was lowered with 3 in. coils and 4 in. blocks in the rear. no probs with rubbing, but i did hit the bump stops with hard bumps.
