Old 07-13-2005, 01:52 AM
badboy00z badboy00z is offline
Bare Metal Foil
Ok, I've got a question. What do you use bare metal foil for?
Old 07-13-2005, 02:15 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Bare Metal Foil
Light lenses (both front and rear), any chrome stripes or window trim, heat shields, chrome shield plates, rim lips, various stripes and fasteners, chrome logos, chrome engine valve covers, motorcycle front forks, discs, exhaust.....etc.
Everything that has to be metal and it is not extremly complex can be covered with BMF.
Sasa Jelic
SCALEMAKERS
Old 07-13-2005, 02:23 AM
Re: Bare Metal Foil
This stuff is self adhesive right??
Old 07-13-2005, 02:49 AM
sjelic's Avatar
Re: Bare Metal Foil
Yes it sticks fine to gloss surfaces but there is also stuff from Microscale that is similar to white glue to help you stick it if there is not enough surface for it self to stick. Great stuff if you ask me. Here is that glue http://www.scaleracecars.com/Merchan...e&Store_Code=S
Sasa Jelic
SCALEMAKERS
Old 07-13-2005, 04:52 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Bare Metal Foil
It can be used for masking, too. When you add the second color after masking, a ridge of paint builds up along the masking tape (especially with a spray can), so the thinner the masking tape, the smaller the ridge is.
Hiroaki Fukuda
Old 07-13-2005, 08:15 AM
klutz_100's Avatar
Re: Re: Bare Metal Foil
amazing stuff for detailed masking and window trim
I'd love for someone to tell me a good way to put it on wheel trim in one piece or at least so that the joins are barely visible though - i've tried but failed spectacularly on that kind of shape !!
Old 07-13-2005, 04:50 PM
Re: Bare Metal Foil
Thanks guys. Klutz, are you talking about the lip on the rims? I don't know if it will work, but try tracing the foil around the rim. Then cut it slightly smaller than the rim. And attach it. Hard to explain w/o pictures. But here's something you can use to get a chrome like finish.
http://www.hlj.com/product/WRK00251
