Old 07-13-2005, 01:38 AM
Toro01 Toro01 is offline
Send a message via MSN to Toro01
cooling fan
Ya my cooling fan is defective seriously though it dont work so im just going throw a toggle swith to it but im unsure what wire to cut and splice. If anyone has done something like this plz help thanks
Old 07-13-2005, 04:11 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
If putting a toggle switch on it will make it work then the fan is good. Something else is bad. Follow me? The problem with a toggle switch is you nee a big one to handle that much electrical current. That's why they have relays. Do you know where the temperature sensor is? If so, try grounding it and see if that turns the fan on. If so, then you just need to replace the temp sensor. If the relay and motor are both good then the togle switch needs to be spiced in to the two wires that actuate the relay. I don't even remember where that relay is but if you need help I can check it out and see. I'm assuming you have the 1.9L engine
Nevada Tumbleweed
Old 07-14-2005, 11:03 AM
ok what i was thinking was that there was a break in the circut between the power and the fan, cause when i play around w/ the battery the battery clicks in but only for a second. As for what u were saying Unfortunitly i dont know where the temperature relay is :P so if u can somehow point out where it would be ill try what ur saying but i dont know what im looking for here sorry
Old 07-14-2005, 03:01 PM
e-mail me your e-mail address and I'll send you a picture of the temp sensor. I have '93 1.9L engine.
[email protected]
Nevada Tumbleweed
Old 07-15-2005, 04:30 AM
Discovered something interesting. When I disconnect the temp sending unit for the cooling fan the fan comes on. No need to ground it. Will e-mail you picture. I'm having problems posting photos here.....
Nevada Tumbleweed
Old 07-20-2005, 10:35 PM
well i tried what u said and it didnt work.. fan didnt do anything
