Old 07-13-2005, 01:19 AM
vtownx vtownx is offline
Send a message via AIM to vtownx
Lightbulb idling problems
ok so what happens is that i start the car up, it sounds fine, but if i pump the accelerator once, the rpms go up, then down, up then down, up then down, and it doesnt stop, it also does sometimes after ive run it for a while and put it in park right before i shut it off. anyone have any ideas?
Old 07-14-2005, 12:47 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Re: idling problems
what year, model and trim are we talking about here?
1986 Honda Accord LX-i 5 spd
Completely stock... but i like it anyway, it's got a strong e-brake
www.cheesemit.us
http://www.cardomain.com/ride/862348/1
Old 07-15-2005, 02:36 AM
90 accord ex, automatic
Old 07-15-2005, 07:51 PM
Deadhead's Avatar
Re: idling problems
sounds like your engine is "surging". This can be caused by a number of things. Have your fast idle control valve checked out along with your EGR valve.
www.cheesemit.us
Old 07-17-2005, 04:27 PM
how would i go about checking these things out? do i need to take it in or is it somtehing i can check out?
Old 07-17-2005, 08:20 PM
Deadhead's Avatar
Re: idling problems
The fast idle control valve is on your intake manifold. Look for a thing that has 2 screws and 2 hoses coming off of it. Open the cap and put your finger in there, if the idle goes to normal, then that's your problem. Take a big screwdriver and screw that thing down until it's snugly in there. That should fix it.
The EGR, i would get some carb cleaner and spray it near the gasket, see if it does anything with the idle at all when you do that.
www.cheesemit.us
Old 08-02-2005, 10:44 AM
Icebox's Avatar
Icebox Icebox is offline
Send a message via AIM to Icebox Send a message via Yahoo to Icebox
Re: idling problems
what is the jump from the rpms? cause our 90 accord ex man is having the same problem. The rpms only shift by 100-200 rpms though. The car idles at about 500. thanks for that imput dead head. We've been trying to figure it out for a while now...
1990 Honda Prelude Si 2.1
My Baby....
Old 08-02-2005, 02:19 PM
Igovert500's Avatar
blue + red light magnet
Re: idling problems
icebox, your problem maybe a bit different. If it is just an erratic idle, I;d check the fast idle control valve as mentioned above, then I'd check for vacuum leaks, check your spark plugs, and possibly even your o2 sensors.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
