Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 07-12-2005, 09:46 PM
mlingk mlingk is offline
o2 bank1/sensor1 removal?
My mpg seems to be going down, and with 105K miles on my 99 trooper I decided to replace the 02 sensors. I replaced the driver side from sensor no problem, but the passager side front sensor connector seems to be up above the transmission housing. Is there a trick to reaching the connector? It seems like I need to actually remove the exhaust pipe to reach the connector? Any hints?
-Thanks, Mike
Old 07-14-2005, 12:27 PM
Re: o2 bank1/sensor1 removal?
Got the sensor replaced... Unless your 4 year-old can reach up and unhook the connector from the metal mount, you'll need to remove the right side exhaust section. It doesn't need to come out, just remove the bolts so you can move it to the side and you can reach a hand up to the connector.
Old 07-28-2005, 11:07 PM
89trooper 89trooper is offline
they make different 02 sensor sockets that make the job easier in most cases. one type is like a deep well socket with a slit up the side the wires go thru, and the other type looks like a crows foot wrench that your ratchet fits on.
email me at [email protected]
Old 07-29-2005, 07:47 AM
My problem was with the wiring harness connector. I couldn't reach it because it was attached way up above the exhaust line. Not enough room to get my arm up to disconnect it... and I really tried!
