Old 07-12-2005, 09:42 PM
oneillchick's Avatar
oneillchick oneillchick is offline
Send a message via MSN to oneillchick Send a message via Yahoo to oneillchick
95' TSi AWD runnin really rough
hey guys
ok i have a 95' TSi AWD 5sp, w/ 81k
and this is what its doing....
i start my car up and it runs fine, but as soon as it gets up to temp it starts idel surging from almost 200rpms to about 1200rmps.... and almost stalls......and about 1/2 the time it does. and when you get goin, the car lurches (ive also heard it described as "bucking") badly, and usally stalls when you slow down (under 10mph)... and its also leakin fuel from the charcoal canister.. i think its just a bad connection...and just fyi the fuel pump was just changed, its a walbro 190.. but the floatee thing isnt in there correctly, because the gauge doesnt register.....anyways any info any of you can give me would be greatly apprecited!!!!!
"Mess with the best...die like the rest"
“no better friend, no worse enemy”
"trained to fight, trained to kill, ready to die, but never will"
1995 Eagle Talon Tsi Awd
- 5sp
- 84K
- 14b turbo
- manual boost controller
- K&N
- walbro 190 fuel pump
- Flowmaster 40seris from muffler back
Old 07-12-2005, 11:16 PM
- 5sp
- 84K
- 14b turbo
- K&N
Old 07-12-2005, 11:27 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: 95' TSi AWD runnin really rough
What do you want us to say? If you can't fix it, you will need to go to a mechanic who can. You might get some info on the idle issue here or searching DSMtuners.com, the fuel leak is a mechanic thing (i didn't know any fuel went to the charcoal canister), and the fuel pump level you might be best off having a DSMer look at.
Old 07-13-2005, 12:33 AM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Re: Re: 95' TSi AWD runnin really rough
I gess I get to do that. She lives a few miles away. 1 of like 3 AWD dsmers in montana it seems.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 07-14-2005, 12:30 PM
kjewer1 kjewer1 is offline
AF - Advisor
First thing I would check is the throttle cable tension. As the motor heats up, the cable jacket expands, and that can open the throttle if there isnt enough slack in the line to start with Somewhere on here I posted a detailed procedure to adjust it, takes 1 minute with a 10mm wrench/socket. Search "throttle" and enter my user name in the user name section, for the main section and the performance section. If you don't have any luck with the search let me know.
Ah screw it, I'm feeling generous. I found many threads, but this one looks the most promising.
http://www.automotiveforums.com/vbul...throttle+cable
Try to do this correctly. If you still have the same problem we can get into further troubleshooting if you want.
For the canister/level problem you're on your own. Very hard to offer any help over the internet for these things. I would bet the fuel pump install is to blame, if these problems both started at that time.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
