Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 07-12-2005, 09:51 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Question Friend's 1990 Sentra - blown head gasket
Hey all, a friend was coming to visit me and blew his head gasket along the way. I'm going to help him replace it tomorrow, but we don't have a tech manual with the head bolt torque specs.
Does anyone have the torque figures for the head bolts? Also, is there a figure for the valve train? Thanks much in advance....
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-13-2005, 08:33 AM
Re: Friend's 1990 Sentra - blown head gasket
Sorry, it's the 1.6L 4 cylinder. Thanks...
Old 07-13-2005, 02:31 PM
SR20B12's Avatar
SR20B12 SR20B12 is offline
Re: Re: Friend's 1990 Sentra - blown head gasket
why even post??? if you don't know.
head bolts bynthe manny says.
bolt nos1-10 step1:22ft. step:2 47ft.
bolt nos11-15 torque last , to 72in lbs.
-5
3
------ 7 13 15 10 8
------9 11 14 12 6
2
-4 1
front of engine bay looking at head.
this is your loosen and tighting pattern.
hope this hlps need more info plz ask.
chip
B12 coupe w/SR20DE
91 AE92 Daily Grinder.
Old 07-13-2005, 02:50 PM
Re: Re: Re: Friend's 1990 Sentra - blown head gasket
I did know, just forgot to put it in last night.
(Thanks btw for the response) but I want to clarify:
1-10 22 ft-lbs, then 47 ft-lbs
then 11-15 to 72 inch-pounds?
We haven't taken it apart yet, so I'm thinking those bolts are a different size to have that much of a difference.
Also, this is the 12-valve motor, 3 valves/cyl. Do you know if this is the dohc version, and any specific tricks of note? (I've done inline 6's and V-8's, but they were all pushrod)
Old 07-14-2005, 01:52 AM
SR20B12's Avatar
Re: Re: Re: Re: Friend's 1990 Sentra - blown head gasket
No. I'm sorry I miss read the post It's not your falt. forgive the
rudeness . your trying to get help
the Ga16I is a SOHC . you could call it a bridge motor for the GA16DE
11-15 start at 22ls. than to a max of 72. the book says 56-72 so any
where in ther should be fine.
tighting them all to 22lbs and loosen than retighten to the 47 for 1-10,and 11-15.
trick ? I don't know any on this engine sorry. other than go out and buy a manual just in case you run into somthing you don't know.
hope this helps. chip
11-15 to 56-72 lbs.
B12 coupe w/SR20DE
Old 07-15-2005, 08:42 AM
Thanks for you help; but it's for naught. He'd had the head gasket replaced before, and the head is warped. We're going to look for a junkyard motor for him.....
Appreciate the input! Didn't think you were rude.....
