Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 07-12-2005, 08:26 PM
megapod megapod is offline
engine won't shut off
any ideas why the engine in my '67 type 1 won't shut off? I replaced the ignition switch, but nothing. currently I have to pull the feed to the distributor to shut it down.
Old 07-12-2005, 10:08 PM
trooperbrett trooperbrett is offline
Re: engine won't shut off
Do you mean it runs just fine with the key turned off? Or does it diesel, run rough and cough when the switch is turned off. If it diesels then it may be the pilot jet, the small cylinder looking thing on the right side of the carb. It may or may not have a wire going to it. If it's broken or dirty it could cause the run on.
If it runs fine with the key off, I don't have a clue, sorry.
Good luck,
Brett
Brett
No Matter Where You Go, There You Are
[IMG][/IMG]
Old 07-13-2005, 01:19 AM
Rick's69's Avatar
Rick's69 Rick's69 is offline
Send a message via AIM to Rick's69
i had the same problem, first, try making sure your lights are off. second your coil is still getting power so that means some wires melted together and are still touching. your going to need a new wiring harness. call around i got my harness for 75 bucks brand new. its easy to rewire, it only took me 2 days to completly rewire my bug. good luck.
-Rick
Old 07-13-2005, 11:50 AM
thanks for the info. since its not dieseling, I guess then there must be a short somewhere. just was hoping there might be something I didn't think of. thanks again!
